I have a 200HP Ocean Runner. It sat for about a year and I've started using it again. I had a water separator on it, but broke it while changing the filter. I emptied the fuel tank and pumped a LOT of replacement fuel out and there was no sign of water or anything in it. I haven't received the replacement water separator yet, but don't think there's a bad gas problem. I also replaced the in-line fuel filter under the cowl with an automotive see-through unit that's a little larger diameter body (stock metal unit was about 3/4" diameter, new is about 1-1/4" diameter. When I took it out (north Texas lake use), I had the following issues.
1. Wouldn't run above about 3500 rpm
2. Wouldn't shut down when key turned off. Cuts out, but will not die unless choked out or revved up and throttle pulled back quickly to idle.
3. Would lose prime
I changed the fuel pump with OEM unit. Hose test shows it still loses prime. I can also see that no matter how much I pump the bulb, there is still air in that filter.
Note- I was using a Moeller Clear Site water separator. Bad product, but cheap at $70. I put it on because I did have big-time water problems in the tank in the past. It's plastic with a pressed in filter adapter. That adapter pulled out when I changed the filter. Just an FYI to those that may think it's a good deal.. not so much!
Thanks in advance for any help rendered!
3. Would lose prime
