97 Johnson 115 sol ID help
Copper_John
I'm looking at an used boat with a 97 Johnson 115 spl. The model number is a J115TSLECM manufactured 9/1997. My issue is that model number is not listed on any parts websites. Could anyone give me an idea of the translation of the model number. I can't upload a pic of the tag at the moment. Size issues.
thanks!
Couple of clicks and I see it for the 1998 model year.
Copper_John
Thanks which designation is the shaft length?
J115TSLECM
T trim and tilt
SL 60 set. Trim and tilt
C year 1998
M ?
EC designates the 98 model year.------It is a long shaft designated by the L-----The M means nothing to you at all.----Where does the 60 come from ?
Copper_John
I was assuming the SL meant 60 Deg. Trim and tilt
thanks for clarifying. I'm new to Johnsons
Then the S would mean Sail - special styling?
Sorry, ----I know where you are getting this information.-----This motor is a 1998 CROSSFLOW 115 HP-----That is according to the parts book.-----Just a standard crossflow and the last year of production..----If you are looking at buying it do a compression test or get a warranty on it.
Copper_John
Its a private seller so I doubt he would give me a warranty. I suppose I could make a compression test a contingency. What should I be expecting for pressure readings?
Can you take it for a test run ?----Most important is that they are all even/ the same.-----My tester would show around 120 psi.----What $ is it listed for ?----Are you able to do repairs yourself ?
Copper_John
No test run possible the ice is barely off the ponds and expecting a foot of snow. The owner started it for me on the cuff. A little smokey but it started and idled after a bit. I guess it was a bit grumpy at turning over in 30f weather. The boat and motor is listed for 5500. The boat is a sweet chris craft sea skiff 18 dc.
lmuss53
The S is for the SPL designation, no VRO oil injection. If the boat is nice that doesn't sound like a bad deal. I'd go back and insist on a compression test, look for numbers within 10% of each other and around 110 or up, then offer him $4500 if you want it.
