1997 evinrude 130 v4 this thing is driving me nuts take it to the lake pump the bulb cranks up perfect water comes out pee hole warms then take off planes out few seconds starts to die like a feul problem have done everything to it that you can imagine everything checks perfect from tank to motor pump the bulb up hard go a little ways same thing the pump looks like new other than fuel could it be somewhere else it will idle all day tried pushing choke does not help still dies stumped this motor looks new pulled spark plug wire off with it running motor changes on every cyl. all the warning light work properly an they so go. wiping the sweat
