97 90hp Johnson lost spark won't run
Leroy5801
I have a 96 Johnson took it out ran it for a couple hours no problem take it to the water the next morning and put it in the water it tried to bust off and after that it was history checked fuel and everything but come to find out I have no spark. I've unhooked lanyard switch and ground from the key and still no spark. I've ran down the basics and have no clue as to what may be.. Even replaced CID box..
gm280
:welcome: aboard Leroy5801, Nice having you join us...
Well if know for certain that you have zero spark on all the cylinders, then you know it isn't the spark plugs or spark plug coils causing such. So start to look at what feeds those coils and work back from there. It has to be something common to all the coils. Before getting too far involved, make absolutely certain you have good grounds and battery power to the engine before going further. And that doesn't mean simply looking at the connections either. Remove them and clean then to shiny metal and reconnect again. The work from there towards the trigger for that spark ignition circuit. Use common logic and think about what is happening and go from there. If you don't have a factory shop manual for your OB, I strongly suggest you buy one! But only the factory, year, HP, model number specific shop manual and not some after market version...
