So I will list the things I've done so far. I have replaced the fuel pump, Carb, brand new filter/water seperator,and new line from tank to filter housing. It idles great and will rev up great in neutral. Once its in gear runs great at low rpms. Once I get to about half throttle it boggs down and dies. I have to crank on the throttle a few times and it will run at low speeds most of the time (yes sea tow is a great investment). I also drained the tank and put in 40gals of fresh gas. I was thinking of hooking up a out board gas tank and see if it still does the same thing. The engine is on a early 80's 26.5 searay. It seems to be starving for fuel.
