97 120 hp mercury Force idle problem
hoyt101
Was out this weekend and 1/2 way through the day the idle would start surging form 1000rpm to 3000rpm. I just ran it all last week and had no
problems could anyone give me an idea where to start.
roscoe
Re: 97 120 hp mercury Force idle problem
Suspect you have dirt in the carbs, causing the problem. Time to clean out the gas tank(s) and fuel line, then rebuild the carbs.
eurolarva
A motor that hunts tends to run lean so you want to get it fixed before it causes damage. Another place to look is all the rubber hoses especially around the quick disconnect. Air may be getting in.
