DeepCMark58A
Thread starter- Joined
- Aug 17, 2015
- 3,536
So I attempted to do a sea trial with the boat but never left the dock. The motor would start and idle, a little bit of a high idle but it ran. The problem is when I tried to put the motor in gear it would die, the motor would restart easily. While I wait for the new fuel pump parts and carb kits I want to do a compression test. Problem is that it will not be possible to warm the engine up first, I just want to see that there is compression and if each cylinder is close in compression levels. I know I need to pull all the plugs and have the carbs open, do I need to lube the cylinders with fuel or fogging oil? Am I wasting my time doing a cold compression test?
