'96 omc 115 turbojet no spark
86 century
Ensign
Re: '96 omc 115 sportjet no spark
Does anyone know what the ohm reading should between the two yellow wires on the charging system side of the stator.
Mine is showing 0ohm or closed and as I am 100 miles or so from my manual any help would be great.
The voltage at the battery eng off is 12.6, running is 12.4 from idle to around 3500rpm.
hidef
It is very low maybe .5 of an Ohm between the yellows. You also want to check both yellows to ground which should be open. Sounds like your rectifier has quit.
86 century
Ensign
Thats what I was thinking to.
I should have known the way my luck goes once I replace one thing everything in the same area will need replaced.
Thanks again
