ddennis
Thread starter- Joined
- Aug 15, 2006
- 351
Could someone tell me if the screw with a spring behind it is the low speed mix adjuster on this model? I only see one externally accessable screw on the carb.
Also how much smoke should I be getting when running on the cups just off idle?
I think it is too lean as I am having a hard time getting a stable idle on this one and it smokes a bit more than I think it should. It will idle for a 10 - 15 secs then starts bogging down and losing rpm.. I can rev it a bit and let it settle down for another 10 - 15 secs and then does the same. Does the carb need to be rebuilt on this?
