crappie_condo
- Feb 25, 2005
- 32
Overheat horn intermittently coming on, as well as intermittent miss/dead cylinder feel at idle. 3/4 of the time it runs fine, but when running for a few miles WOT the overheat horn comes on even though the motor is not hot or missing out. The Tach. has been flakey also jumping all around, does this sound like a regulator?? It is water cooled. Replaced the regulator ~5yrs ago for not charging the batt.
Compression test results
Port Starboard
Top-120 Top-124
Bottom-112 Bottom-120
Pic of plugs, bottom port side is dry and also has the lowest compression. Any input appreciated........
Port Starboard
Top-120 Top-124
