96 johnson 112 overheat left side
j112tsledr
I have 112 that overheated on left side, motor runs good, new impellar in water pump, was melted. Why overheating on one side and where is thermostat located.
tashasdaddy
Re: 96 johnson 112 overheat left side
you have 2 thermostats, one for each side, lower back between heads, you will see a hose from each head. melted impellers no water flow, either the water tube was blocked, pinched water tube grommet. that could have caused the alarm.
