96 Evinrude 35hp 3 Cylinder Draining Battery
jeff_32
If I don't keep the battery on charge before I go use it there will be no charge at all. Brand new battery that I already had checked and used on another 25hp 2 cylinder without a problem. Where can I start checking to fix this problem. I've heard that some of these 3 cylinders had electrical problems.
SparkieBoat
Re: 96 Evinrude 35hp 3 Cylinder Draining Battery
see if the is any volt draw while motor is turned off..maybe a short somewhere..
F_R
Honorary Supreme Mariner
Test your rectifier.
