96 Evinrude 115 2-stroke keeps eating pistons
Used Car Salesman
Hey guys, I've come into a new project and I'm looking for some input.
The motor is a 1996 Evinrude 115, V4 2-stroke. It has scored #2 (starboard top) cylinder that looks like it is probably the result of a broken piston ring. The outboard is on it's 3rd powerhead since it was purchased new. In 2010, 2013 and 2014 it has suffered similar failures and loss of compression in that same #2 cylinder. The previous owner kept throwing money at it, but apparently never fixed the root problem.
The powerhead is out currently and partially stripped. I'm in the process of looking for a machine shop that can bore it over and put in a new cylinder. That's gonna cost at least a few hundred dollars, and I really don't want to put it all back together only to have the same cylinder fail again.
So my question is: What should I be checking in the process of putting this thing back together to make sure it doesn't burn up again? My current theory is something is going on with that barrel of the carb that runs it lean and overheats it. A VRO2 failure would screw up ALL the cylinders, right? The carbs have been rebuilt several times, but not by a professional shop.
In addition to things I should be checking, what can I do to make sure I shut the motor down first in case it does start overheating? I've googled around and seen people talking about individual temp sensors for each cylinder, instead of trusting (what I assume is) a single water temp sensor for the whole thing. What would that kind of setup look like?
Thanks
Use WISECO pistons and rings.-----Make sure motor is running with the correct prop for the boat / load that is in the boat.---As far as I know that motor has 2 water temp sensors, one in each head.----And check the thermostats and poppit valves.---Replace water diverters / deflectors too.
emdsapmgr
OMC made two distinctly different 115's that year. The older 90-degree crossflow and the newer 60-degree looper. Pls post the model # of the engine you are working on.
Grub54891
Sounds similar to one I repaired quite a few years back. It was a 70 hp 3 cyl but it wrecked the middle piston. The shop owner repaired it. Then sold the shop, under the new owner, we sold it to a customer, blew the middle cyl again. I tore it down, replaced all electrical components, piston etc...When assembling I noticed the inner ring on the flywheel was wiggly, we compared it to another we had there, and it had indeed slipped around a slight amount. You could set the timing, and it looked good, but we figure it would slip a tad again under operating conditions and knock the timing off. The teacher from the tech school in the area happens by, and took the wheel to the school for a teaching aid so student's could learn from it. After replacing the wheel, it never had another issue.
scamp12
Post some pics of the piston thats damaged. Reading the parts really helps one figure why its burning piston and rings which is heat and detonation. Whats the #2 spark plug look like . White any little black flakes on the porcelain. If so that aluminum from the piston. And a very lean mixture on that bank
