Used Car Salesman
Thread starter- Joined
- Sep 13, 2015
- 1
Hey guys, I've come into a new project and I'm looking for some input.
The motor is a 1996 Evinrude 115, V4 2-stroke. It has scored #2 (starboard top) cylinder that looks like it is probably the result of a broken piston ring. The outboard is on it's 3rd powerhead since it was purchased new. In 2010, 2013 and 2014 it has suffered similar failures and loss of compression in that same #2 cylinder. The previous owner kept throwing money at it, but apparently never fixed the root problem.
The powerhead is out currently and partially stripped. I'm in the process of looking for a machine shop that can bore it over and put in a new cylinder. That's gonna cost at least a few hundred dollars, and I really don't want to put it all back together only to have the same cylinder fail again.
So my question is: What should I be checking in the process of putting this thing back together to make sure it doesn't burn up again? My current theory is something is going on with that barrel of the carb that runs it lean and overheats it. A VRO2 failure would screw up ALL the cylinders, right? The carbs have been rebuilt several times, but not by a professional shop.
In addition to things I should be checking, what can I do to make sure I shut the motor down first in case it does start overheating? I've googled around and seen people talking about individual temp sensors for each cylinder, instead of trusting (what I assume is) a single water temp sensor for the whole thing. What would that kind of setup look like?
Thanks
Thanks
