96' 50 johnson odd idle issue
whalerfreak22
Ive heard these series motors (40,48,50)dont like to idle but ive got a strange problem.when the motor is tilted all the way down it sounds like its running on 1 cyl or barely two(it almost wants to stall) but when i trim it up half way before the cavatation plates out of the water it runs very smooth.anyone ever have this issue or know how to diagnose it?:confused:
-Keith
boobie
Re: 96' 50 johnson odd idle issue
Get a good insulated pliers and do a cyl drop test on it to see if both cyl's are firing. Pull one spark plug wire off at a time and see if you notice a drop in rpm. The cyl that doesn't drop could have fuel, ignition or compression probs.
