Pro Crappie Guide
Thread starter- Joined
- May 6, 2002
- 32
I have a 1996 Johnson Outboard, 50 h.p. triple, oil injection.<br /><br />I have had intermittent problems with the motor stalling. <br /><br />When I travel at speeds above 1/2 throttle, the motor will shut off, just like I turned off the key. This will happen after about 1/2 mile of travel. However, it fires right back up without any rough idle or hesitation, and without priming, choking, etc.<br /><br />I have run the motor at closed to 1/4 throttle for extended periods since the problem originally occured, and it has not done it at those engine speeds. <br /><br />If the power pack goes bad, does it usually give intermittent problems like this? I have had one go bad before, and it was dead. End of story.<br /><br />Thanks for your help guys,<br /><br />PCG
