That's not enough motor for the boat. I know this because I had one. That said, the prop should be 12-1/4 x 15P and no more. The boat is rated for a 75 HP. However, if the engine will not rev above 2500 rpm, make sure it is not in SAFE mode which is triggered by the overheat sensor. Do you you get the audible warning when the key is turned to the RUN position. If not, the warning system is not working.
