Re: 96 4.3 mercrusier engine knocking
Should of changed oil before starting,damage may be done by you running engine with water in the oil,if that is the case.The answer will be for you to see if it comes out looking like a milkshake,which you might also notice on the dipstick that might read high if it took in a lot of water.You may want to post in the mercruiser forum instead of the mercury forum as well,good luck.
