96 25 hp evinrude fuel confusion
Dw662002
Recently purchased 1st boat. Has 1996 evinrude. I filled the tank with regular unleaded fuel and was then told non-ethanol only. My question is should I drain the tank or would it hurt to run 1 tank thru and fill up with the right stuff. Any advice would be welcome. Thanks
Rustywrench
Many people prefer to run ethanol free fuel, but it is not required in your motor. Ethanol laden fuels do not store well when not in use therefore some like to avoid its use.
Lightwin 3
As long as the fuel is E 10 (10%) or lower, you're fine. No: E 15, 20 or 85.
If it is going to sit for long periods, add a stabilizer such as StaBil.
boobie
I only use the ethanol free fuel with a stabilizer added. Never know when the boat may sit for awhile.
Crosbyman
13 years on my ETEC 75 with ethanol gas 2+4D stabilizer stored 6 months per year down to -20- 25 F in th garage
never had any issues with ethanol gas
now just in case..... I winter store it full tank with ethanol free high octane and 2+4d but I dump that gas in the Spring for the lawn tractor and weed eater refill with ethanol
no issues
Dw662002
Thanks for the info fellow boaters. I just want sure. I plan on running nothing but ethanol free from now on. Just a rookie mistake. Didn't know if it had any immediate dangers.
