96,200 oceanrunner,vro conversion questions
h20fish
Help, i have decided to do away with vro pump, i bought a new fuel only pump today 18-7353 sierra, is this the correct vacuum type pump to use ? and i also would like some instructions on how to do this if this is correct pump
Chris1956
Re: 96,200 oceanrunner,vro conversion questions
H2O, You may reuse your current OMS pump, with premix, by capping the oil intake, and disconnecting the wiring harness.
h20fish
,,, THANKS CHRIS1956,, THE FUEL SIDE OF THE "VRO2/OMS" IS BAD AND I WISH TO REPLACE IT TOTALLY, WITH OUT GOING ELECTRIC,, IS THE SIRRRA PUMP I MENTION SUFFICIENT ?
ezeke
A single lift pump is inadequate for your motor, You would require two lift pumps in tandem with large capacity such as the OEM # 0438559 + 393870.
If the gasoline side of your OMS pump is still good, you should consider the advice of Chris1956. Also, if it is faulty, the gasoline side of your pump can be rebuilt with a kit for less than $100. to use for premix only.
The VRO, VRO2 or OMS systems are all mechanical. The only thing electric is the warning system.
