'96 150 Evinrude boggs down at take off
czechfish
boat starts and idles great. when i give it throttle on take off, slow or fast, it boggs down and dies. i have to pump the primer bulb before or pump the choke switch during take off to get out of the hole. after that no problems runs like a scalded dog(65mph). any suggestions would be grately appreciated!
HighTrim
Re: '96 150 Evinrude boggs down at take off
When were the carbs last rebuilt? Definately sounds like a fuel restriction problem.
czechfish
rebuilt carbs last spring. the mechanic was stumped after all the work he did on the carbs.
HighTrim
If pumping the primer bulb helps, check into the carb floats improperly set or defective, failing fuel pump air motor diaphragm , leaky or dislodged pulse hose between crankcase and fuel pump.
Get a vacuum gauge and hook it inline on the fuel hose before the engine, along with a clear section of hose. Take it for a spin, noting the readings and monitor the fuel flow through the clear hose.
Findings:
-Vacuum of less than 2 inches and air bubbles in the clear hose indicates an air leak into the fuel system
-No air bubbles and less than 2 inches indicates a bad fuel pump
-Vacuum over 4 inches indicates a restriction.
Sample gauge
"http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&sspagename=STRK%3AMEBTOX%3AIT&viewitem=&item=4610113711&_trksid=p3984.cTODAY.m238.lVI"
czechfish
thanks alot! i appreciate your knowledge
