96Islander
Thread starter- Joined
- May 18, 2010
- 9
Just picked up this 1995 Starcraft Islander 19' with the Mercruiser 3.0lx fresh water cooled and Alpha 1 drive that was mainly used in freshwater. I bought the boat and the oil was not milky at all he started it and ran it with water for about 10 minutes and everything checked out fine. I then took it out to the lake the following day after I changed the oil and filter, it was kinda dirty. I had it out for maybe an hour of runtime, watched all gauges and it did not get hot but the oil has a milky color to it no bubbles. I'm not new to engine's but haven't worked alot on marine engines. I know there are some 3.0 gurus on here...what things should I check before I pull the head off and check block/headgasket? Also the drive resevoir was full when I took it out and was almost empty by the time I got back it leaked in the bilge area. Heard no odd noises so the engine is fine just need to figure out where this water is coming in from. Thanks for any input.
