95 johnson outboard trottle cable
jcostilla78221
New to this forum, I have a johnson 95 112hp, i replaced lower unit with a used one, got everything back in place, but i thing i did not do was take pictures of trottle and shift linkage when i removed them, when testing motor i move gear lever to full trottle but it is very hard to move it. need to know if anyone can post pictures of how the trottle and shift levers look like when correctly installed, don't know if i mistakenly reversed trottle and shift cables, any help would be appreicated.
82rude
Very simple.Disconnect your cables at the motor.The very first cable to move when you shift from neutral to forward or rev is the shift cable.
