95 Johnson 48hp troubles
jdeller
The motor is new to me and apparently was sitting for 2 years or so. Motor runs fine on muffs, but on the water won't go full speed only half or less. At around mid throttle or so it revs up and down on its own, but when I give it more throttle it will go faster for 2 seconds but bogs back down. As I was driving around I pushed in the ignition key for choke ad held it in and the rpms picked up but not much. if I put it in idle it stalls out and acts like its flooded. please help thanks.
gm280
First thing jdeller, :welcome: to iboats...
I have to agree with ondarvr. Time to remove, disassembly and totally clean the carbs and install carb kits in them. And don't just spray some carb spray and reassemble them again. Remove all the jets and needles and make absolutely certain that every hole and slot is perfectly clean. Then reassemble them and happy boating again... :thumb:
jdeller
okay thanks ondarvr, and gm280 I'll do that and let you know how that worked.
