95 intrude 115 will crank but wont run
gboat72
the original problem was it ran good but didnt want to idle, the red choke valve lever was cracked and leaking fuel, it was replaced, then the carbs were cleaned, it ran fine no issues,next trip out, it starts then dies, it will rev up, but if you let off the throttle it will die, just put new plugs and head o-rings in it,didnt help. any thoughts would be helpfull. it looks like it has pistons from 3 different sets....please help
