95 Force 120 timing specs
seldont
What is the timing spec for a 95 Force 120?? At idle, wide open throttle or static timing while cranking before the engine starts.
seldont
Re: 95 Force 120 timing specs
Thanks Doc. I hope I can crank it long enough to check it without it starting. Seemingly different than many others on this forum my 120 likes to start real quick unless it has been sitting for quite some time. Timing should be okay but I would just like to check it anyway. Wanna decarbon and synch before putting away for the winter. I know it has not been checked cause I bought it new in 95. Only thing ever replaced was the stator 2 years ago and the spark plugs. I promise I will put an impeller in before spring!! I do not have the manual. Any tricks on this one to putting the impeller in???
