95 fast strike WOT bogging
Sw.anderson
I'm really hoping someone can help shed some light on an issue I'm having with my 1995 Johnson Fastrike 115. I've had this issue for months now and everything I have tried hadn't worked. The boat starts and runs well up to about 4,000rpms. If I try to accelerate passed that it starts bogging down however if I pull back on the throttle and get it back to the 4,000 range it will run all day long that way. I had it out the other day and hit the choke on the key when it started bogging down and it picked up and ran all the way up to 5700rpms like it's supposed to. To keep it at 5700 I had to keep hitting the choke button otherwise it would bog down. It seems like it's starving for fuel to me. So far the fuel filter has been replaced as well as the primer bulb. The carbs have been completely rebuilt and new high speed jets installed. None of that has helped. Someone said it could be the vapor separator or the fuel pump I'm hoping it's not the fuel pump. Is there a way to check and make sure it's working? I've also visually inspected the fuel lines and they "appear" okay but they are the originals. Any other thoughts?
Here's a quick update from looking at the motor today. I noticed the cover for the primer solenoid is cracked. Could that allow enough air in the system to cause my issue?
Honorary Supreme Mariner
Pushing the key in opens the primer valve.---This action injects fuel into the engine.---This fuel bypasses the carburetors.----That clearly points at carburetor issues.---But get the repair part for the primer valve as that is an easy fix to do first.
bob johnson
pull the bowls and clean them out and clean the high speed orifice.....as well as getting the primer solenoid repaired.....also make sure the red valve is pointing in the right direction when reinstalled... Id also make sure the filter on the front of the engine is clean....as well as any other filter you might have...
bob
Sw.anderson
So you are thinking it's not the fuel pump? When the carburetors were rebuilt, shouldn't that have cured any issues with them. The mechanic seemed confident in his work and I am certainly no mechanic. I appreciate the advice.
