'95 Evinrude System Check
JeromeyS
We have a '95 Crestliner with a 130 Evinrude. Went out to the lake last week we had just left the dock (still at idle) and the System Check started beeping, beep...beep...beep...etc. I turned it off and checked the oil- it was just under half but topped it up anyways. Fired it up again and it started beeping again. Checked the pee hole and it was spraying water out of there (I had a new water pump installed this spring and had the water hoses cleaned out as well). Did this 2 more times and it went away. We used the boat the rest of the week and never encountered the issue again. I have read that the System Check lights were required for '96 and newer. Is it possible to install either the tach or a 2" gauge with lights on this? It would be nice to know what the problem is rather than having to guess and then it go away and not know what was happenning.
