95 Evinrude Intruder 150
CSP13
I have been having some problems with my motor (missing or coughing) when idling while in gear. Motor seems to run fine when you give it gas and run. Today on the lake the motor would die rather than miss. Always fires right back up. Any thoughts or help would be greatly appreciated.
boobie
Start out with a compression test and then a good sync & link on it.
James R
It can get complicated on these models however your symptoms are indicative of blocked idle jets. When were the carbs last stripped and cleaned, Do you use Stabil Marine in your fuel and is a Water trap filter fitted in the fuel line.
emdsapmgr
A occasional cough at dead idle can be known as a "lean sneeze." It's due to a lean mixture in the idle passages in the carb. If those idle passages get restricted with dried fuel gelatin over time, it will run lean at idle. Common for an occasional cough symptom-only while at idle. Not an ignition problem, but carb related. You will need to pull the carbs apart and clean the dried fuel out with an aerosol type product-like GUMOUT. Once you crack the throttle slightly, other jets deliver fuel and it may run just fine through the rest of the rpm range.
fhhuber
A few possibilities ... I'd start cheap and easy.
Check the spark plugs.
Faztbullet
The is also a TSB on these models. If it has the black intake manifold gasket it needs to be changed to the tan one as it dries out and cracks causing air leaks...
