:welcome: Retrevr to iboats. Glad you could join us...
I have to say that I don't understand what you're saying. What fuel line from the manifold are you taking off. If this is from the fuel pump to the carb(s) then sure seems like your fuel pump. When you squeeze the primer bulb and fuel comes through, you verified that the fuel lines are not plugged. So if you are not getting any fuel out the line from the fuel pump to the carb when you are cranking it, then yes you either need to rebuild the fuel pump or replace it. Depending what you are capable of doing, a fuel pump kit would most like be the cheapest and easiest way to fix it... So if you meant to say from the fuel pump to the carb(s) then you have a bad fuel pump. But if it is some other fuel line, then that changes everything. JMHO!
