Hello everyone, long time lurker but first time poster. I have a 1995 Evinrude 150 intruder that has me stumped. Usually I can diagnose and fix these old outboards fairly easy but this is my first looper. Motor has good compression, between 105-115 across all 6. Motor will run all day when I'm up on plane but when I'm idling through a no wake zone it will run out of fuel after a few minutes. If I prime the bulb back up it runs another few minutes and repeats the process. I started by replacing the primer bulb and checking all my lines/connections for leaks. I found one small leak in the vacuum switch where it has cracked, blocked it off to test while another one is in the mail but the problem is still there. I've also taken the VRO pump off, which is bypassed and just running premix. No hole in the diagphram and the pulse line seems to have good pressure. Sorry for the long post, any help is much appreciated.
