95 cajun 1850 center console
valsanch15
hello out there. well im having a bit of a problem and could use some help..i bought this boat off my friend and the wiring is all jacked up. instead of unplugging and coding the wires the just went snip snip. so i guess what im wanting to know is does anyone know where i can find an electrical wiring diagram for this boat or who to call to purchase a boat manual?
rcmjtx
Re: 95 cajun 1850 center console
I had the exact same problem with a Cajun Center Console I bought in October. I searched the web and found some good info. The following shows to be for a 1992 but I got this from a generic color code chart and it matched exactly.
1992 Cajun 1850 Travis Edition
Wire Color Codes
Igintion Control
Wire Color Function Apply
BLACK/YELLOW Eingine Shutdown GND
YELLOW/RED Engine Startup 12V
BLACK Battery Ground GND
PURPLE Ignition 12V
RED/PURPLE Battery 12V 12V
PURPLE/WHITE Choke 12V
GRAY Tachometer Pulse Sender Pulse Signal
TAN Alarm Sender Signal
Trim Control
GREEN/WHITE Trim Down 12V
WHITE/BROWN Trim Gauge Sender Signal
BLUE/WHITE Trim Up 12V
BROWN/BLACK Trim Gauge Negative GND
RED/WHITE Trim Gauge Positive 12v
Wire Color Function
BLACK Low Voltage Ground Return
PINK Fuel Sending Unit
GRAY/GREEN FWD Navigation Lights
GRAY/BLUE Stern Navigation Lights
RED/BLACK Windlass Up
BROWN/ORANGE AFT Bilge Pump
Standard Gauge Wire Color Codes
Wire Color Function Symbol
BLACK Ground G
PURPLE Ignition I
PINK Fuel Sending Unit S
BLUE Navigation Lights
Gray Tachometer Pulse Sender PUL
