95 70hp force no spark
bullet09
Put the boat in the water fired up fine then i got up to move something and the boat idled out, tried to fire it back up but would not go. checked the plugs and see they had no spark. Since then I have replaced the cdi box, checked all the connections and bypassed the kill switch and i still have no spark. Any suggestions on what i can do next.
THANK YOU
roscoe
Re: 95 70hp force no spark
You can check the resistance between the red and blue wires coming off the stator.
Disconnect them from the bullet connectors, check resistance.
Don't have my manual here, so can't give you the acceptable numbers. But if its 0 or infinity, it would be a bad thing.
bullet09
dumb question but how to i check the resistance on the wires with my multimeter?
bullet09
The only way i could get a reading off the wire is put the red probe of my meter in the red wire coming off the stator and the black on a ground, i got different reading depending on what i had the ohms at. I could not get any reading off the blue wire
roscoe
Connect probes to red and blue.
bullet09
I just did and got no reading and any ohm setting
