This motor has been sitting for 3 years. I have fresh gas, and have gone through everything to the carbs including the plastic mixer chamber and fresh gas is getting there. New filter full of fuel. I learned a long time that you have to drain the bottom of the carbs of all the oil that gets in there and I have done that. Bulb stays full and it fires fine with carb cleaner sprayed into each cylinder. All the lines were full of straight 2 cycle oil and that has all been cleaned out. Like I said gas is getting everywhere.
I have not hooked up the oil reservoir to the motor yet. I want to just get a fire or it will just pump everything full of oil it seems.
I imagine everyone is thinking carburetors. That is my next step I guess. Hoping for some help here.
Thanks
Thanks
