i have a 95 150 oceanrunner that just started having problems first it wouldn't get wot and had a gas smell from the engine found out 1 carb was leaking.had it rebuilt no more leak but now the engine runs worse than before spitting and cutting off at idle wont even go to half throttle replaced the plugs the fuel filter hoses and put on new clamps what else could be the problem it used to pick up speed if you pushed the choke in now it dies out i just got the manuel to help me trobleshoot the problem any ideas on where to start
