94 searay jetboat 90 hp force moter
beverly10
Hi I just got a 94 searay rader jetboat I have no spark I replaced the flywheel trigger and stater also coils and still no spark Also i do not have a swich box...Can anyone help please.. i also check wires and all were good
Boomyal
Re: 94 searay jetboat 90 hp force moter
beverly, this is the OMC inboard/outboard sterndrive forum. We know nothing about outboards motors. You need to post your questions in the "Force & Chrysler Outboards" forum.
jerryjerry05
Actually she needs to post in the PWC section.
I think??The 94/90 came with 2 different ignition systems.
Need to know what the serial#s or model#s are.Pics help.
If you have replaced the main parts?Possibly the kill switch,key switch isin't working?
Fill out the profile,location? You might be close to someone who can help?
beverly10
I eliminated the kill switch and still no fire ... thanks for ur help
jerryjerry05
Serial#s model#s???
Outboard ignition . com has test procedures.
No switch box?? It needs some kind of control box?
beverly10
The boat had a cdi in it. But someone put cdm... I just got this boat and the serial number was a sticker and i went to go wipe it of from oil and it wiped off i cant see it from the back but it is a 1994 searay rayder 90hp force motor we have put everything new but the trigger. will the trigger make it not fair out of the coil. getting fire to coil but not out. if that makes sense
