G'day<br /><br />I have a 1994 30hp Mercury Sea pro, the problem I have is that when I am travelling at speed (above half throttle)the motor has a tendancy to just die, lose power. If I throttle down it will idel along, but if I increase the throttle it will stop. It will then start just fine and off you go again. I have noticed that if I press the fuel primer (continuously)when it is dying it will pick up and go, until you stop pressing the primer. <br /><br />I have had one of the coil packs repalced, the motor just stopped one day and wouldn't start. <br />Would the coil pack have anything to do with the problem? <br /><br />It is a bit unerving when it just stops, for this reason I haven't taken it out any bars incase it stops when traversing one.<br /><br />Also does anyone have an exploded view diagram of my motor? I need to replace an impeller.<br /><br />Cheers from down under <br /><br />Deza
