Dustin Taylor
- Jun 16, 2015
- 1
Not so quick history: I have a 94 Bass Tracker with a Mercury 25hp 2 stroke. She has always been a reliable engine. Several years back I had issues starting the engine from the ignition when cold. Sometimes it would work and sometimes I would have to use the pull starter. After running it initially, it would start via the ignition without issue throughout the trip. As time went on however, it would be hit or miss as to the ignition firing after doing that first pull start. Then, as you can guess, the ignition failed to work al together. It has been like this for a few seasons now and pull starting it was never difficult. I of course would turn the ignition key, choke and she would fire up in a few pulls cold or a single when warm. Fast forward to this season. After my initial check for it's first run I found that the inline fuse going to the starter battery from the console had corroded and broken off. No big deal, we were just doing a quick run around the lake. Before we put it in new spark plugs, hooked it up to the hose, turned the key, pulled a few times and it started. Put it in the lake and went the whole trip without issue, starting and stopping the motor several times and always checking the impeller was running water. I brought it back and replaced the inline fuse and put in a 20amp. I tried a 10amp first because I didn't know what I should use and it was corroded beyond recognition. With the 10amp I couldn't even hear the bilge but the 20amp seemed to be fine. Double checked that all the wiring was properly connected back to the starter and trolling battery. Went out the following weekend, added 6 gallons of fresh fuel and oil, dropped it in the water, pulled the started till my arm fell off and could not get it to fire. Checked landyard switch and it wasn't the issue. I don't think it is the inline fuse I replaced as it worked when it was completely severed. What could prevent it from being pull started when it was perfectly fine the week before? The ignition I understand, and if anyone could give insight into that it would be appreciated but I have basically not using it for years (I can faintly hear it trying to crank when I turn the ignition). Any help is appreciated. Thanks! Oh, my own personal diagnosis was my fishing buddy bragging to the other guy at the ramp that day about how we have never had an issue with the engine in over 15 years. I still blame his mouth.
