'94 Johnson Sailmaster 9.9 - Wiring Harness / ignition question
smitty225
I'm trying salvage my mess of a wiring harness, but I'm having no luck. The PO built a funky panel to house the ignition switch, but the switch is corroded and needs recabling. Next to the switch is a corroded and non functioning toggle switch that looks like its supposed to be connected to the ignition switch, but isn't. Is this an emergency cut off switch? Or something else? Also, is it supposed to be connected to the ignition switch? If so, how? Also, the cables in the pic run back to the battery.
Smitty
F_R
I'd say it is a choke/primer switch
smitty225
On the ignition switch, you push the key in and then turn to activate the choke/primer.
