mark_lybarger
- Jul 16, 2005
- 8
i've got a 1994 20' genesis with a mercruiser 180 hp 4.3L (?) inboard motor. i recently purchased it and am a green boater. <br /><br />the first time on the water it worked nicely. it took a little starting fluid to get it started, but we drove it for about 1.5 hrs on the water, no hitch. then in the afternoon, we took it out and had troubles starting it. it seems to have enough battery (we tried hooking jumper cables up to the truck, but no help). when turning the key, the belts and such don't turn. only a grinding type noise. perhaps the starter isn't engaging or something like that? we cranked it quite a bit the 2nd time out while trying to start it and may have done some damage with too much cranking?<br /><br />any ideas, thoughts, suggestions, etc would be most appreciated. the started seems a bit challenging to get to being that it's on the lower back end. i've changed many a car starters in my day, but like i've said i'm rather green to boating. i'm a bit nervous about the break out another thousand i've heard so much about...<br /><br />thanks!<br />~mark
