94 four winns I want thru hull exhaust!!!
B20forlife
I have a 1994 Four Winns horizon with a fuel injected 5.0 ford cobra engine. I really want thru hull exhaust but can't seem to find a kit. Does anyone know were I can buy a kit for my boat? I know about the loudness and all that. I driven manny cars with open header or super loud exhaust as daily drivers so the loudness doesn't affect me so much. Thanks everyone hope you guys can help me out
tazrig
Re: 94 four winns I want thru hull exhaust!!!
It's not so much about you being able to take the noise it's about the rest of us who can't or don't want to. That being said, you're probably going to find it near impossible to find a kit because of the vintage of your motor. I would just go to my local muffler shop and have them cut and bend some stainless pipe to fit you're application. Just run it straight back from the risers through the transom being sure to insulate the pipe (temperature) from the transom walls and seal it tight at the riser end so you don't develop a fume problem.
Ayuh,.... Welcome Aboard,.... There are no "Kits",.... You'll need to buy the pipes, by the piece,....
Parts can be found at the "Off-shore", "Poker-run" kinda boat shops,...
It shouldn't set ya back much more than a Grand, or Two, or Three,...
Btw,.... You'll most likely Loose performance, as ya can't change the fuel map of yer Efi to match the change to the exhaust,....
But hey,.... Enjoy the Noise,......
Walt T
Buy the Captains Call cut off valves and make it so you can switch between open and thru drive exhaust. Some lakes don't allow open exhaust for good reason. I'm a performance engine builder, I grew up listening to open exhaust drag boats. I do like the sound but not when I'm out on a lake with my family in the family boat. It's not appropriate and no one cares. You may as well hang a sign on your boat that say's "Jerk Driving!" Actually I would use a word that describes a most celebrated part of the human anatomy instead of 'Jerk' but I think the forum has high expectations of loquacity and elucidation.
boobie
To me that's not noise, it's MUSIC. I grew up with a Daddy who raced stock cars and always loved the sound.
