First thank you for all that you do in your blogs. I am a novice mechanic (more like infantile) but your info has been great.
I have a 94 Force 120HP with what was an intermittent trim problem and pray you can tell me it?s the Relays, replace them and I am good to go! I have been having difficulty whereas the trim would not work at all, I start the engine and out of nowhere everything would be fine. Now all I get is a single CLICK from the Relays when I attempt to go up or down. I noticed at one point in my tinkering that the trim motor felt a little warm as well as the positive wire coming from the starter relay and feeding the two trim relays but cold on the other side of the relays (the blue and green wires)? I DO NOT have the circuit breaker between the starter and the relays as I have seen suggested in some of the posts?
This happened to me seven or eight months ago and I took it in and my mechanic yelled at me and said ?WIRE BRUSH MY MAN?. I took off all the connections at the relays one at a time and brushed every one but still have nothing?
Please tell me it?s a $40 repair for two relays that I can do myself and NOT a $200 plus repair for a motor that I am skeptical of doing because I have no idea what I am doing?
I hope you can help! Thanks
Also, I have not tried going directly from the motor to the battery as I just learned of that technique in the blogs today.
