94 evinrude 200hp
luv2fish1987
Alright so a while back i had a problem with no spark got it worked on and come to find out it was the stator the mech replaced the stator rectifier power pack and plugs now it has spark and starts great but when i take it to the lake it will run fine in reverse and will rev up in neutral and idol fine but in the water under load when i try to get on plane it will get to about 2000 rpms and bog down and wont get on plane so i looked at the carbs and they were all fine i did have one that was leaking from the seal in between the bowl so i replace i noticed when i start the motor fuel will shoot out of a hose under the bottem carb this fuel line comes from the middle of the motor can anyone tell me what this is and could my prob have been the seal on the carb thanks for any help also now when i start it the motor backfires one time and seems to run fine.
