94 evinrude 200hp no spark
luv2fish1987
need a little help 94 evinrude 200hp getting no spark boat was running good than it started when i would try to get on plane sometimes when i gave it gas i would have very little power and have to try again than it got to were it would be hard to get the motor started in the mornings it seemed not all cylinders were getting spark that i would have to pull a plug and barley put it in the cylinder to get it started but after first start it would start fine and run good all day long than my starter went out and by the time i changed it the boat set for a while now it will turn but no spark but i also had a new battery in it witch i guess has gone bad because it will not charge and when i hook it up it says check connection does this sound like a rectifier prob i am lost and need some help i have tried a used stator and powerpack that did not due the trick.
Joe Reeves
Re: 94 evinrude 200hp no spark
I retired back in 1991 so your engine's design and circuitry is somewhat foreign to me, however I'll offer a few suggestions just so that your post will be re-entered to the top of the list once more where other members might notice it better.
The engine must crank over at least 300 rpm in order for the stator to energize the powerpack. If you have a slow cranking engine, the ignition/spark will be weak, erratic, or non existent. Make sure that "ALL" of the cable/wire connections/terminals and the components they attach to are actually clean and tight, otherwise a voltage drop will exist that will result in a slow cranking electric starter.
Remove the "Black/Yellow" (kill circuit) wire from the ignition switch. If you now have spark with that wire disconnected BUT faulty spark with it connected, the ignition switch has a intermittent short... replace the ignition switch.
luv2fish1987
Thanks for the help I will try this when I get home today thanks again.
Joe Reeves
Seeing as how no other member has jumped in here yet, I'll throw in a few more suggestions that may or may not apply to that model if for no other reason to keep your post active.
The statement about losing the battery charging feature could indicate that the stator has started melting down. This would result in a AC voltage drop to the powerpack's capacitor... in turn resulting in weak, erratic, or no ignition/spark. Usually you can actually see the sticky looking substance dripping down off the stator onto the powerhead area. Look for two large black coils on the stator as these are the two coils that apply voltage to the powerpack.
If the voltage regulator/rectifier failed, that should also disengage the tachometer... the tachometer would simply not function. If this is the case, you can use the tachometer to run a test as follows:
(Testing Tachometer With Water Cooled Regulator/Rectifier)
(J. Reeves)
A quick check is to simply plug in a another new tachometer as a piece of test equipment. If the new tach works properly and the old tach didn't, obviously the old tach is faulty.... but usually boaters don't carry around a spare tach (see below).
A faulty rectifier wouldn't damage the tachometer, the tachometer simply wouldn't work. This is due to the fact that the tachometer operates off of the charging system and the rectifier converts AC voltage to DC voltage, enabling the charging system. A faulty rectifier disables the charging system, and the tachometer simply doesn't register.
However.... those water cooled regulator/rectifiers that are used on the 35 ampere charging systems (and some others) bring into play a different type problem, and as you've probably found out, they are really a pain to troubleshoot via the proper procedure. There's an easier way.
The tachometer sending/receiving setup operates off of the gray wire at the tachometer. That same gray wire exists at the engine wiring harness which is connected to the engine electrical terminal strip. You'll see that there is a gray wire leading from the regulator/rectifier to that terminal strip, and that there is another gray wire attached to it. That other gray wire is the wire leading to the tachometer which is the one you're looking for.
NOTE: For the later models that DO NOT incorporate a wiring terminal strip, splicing into the "Yellow Wire" mentioned will be necessary.
Normally the Gray wire leading from the tachometer is attached at the terminal strip to another Gray wire which leads from the water cooled voltage regulator/rectifier...... remove the gray wire that leads to the tachometer. Now, find the two (2) yellow wires leading from the stator to that terminal strip. Hopefully one of them is either yellow/gray or is connected to a yellow/gray wire at the terminal strip. If so, connect the gray wire you removed previously to that yellow/gray terminal. Start the engine and check the tachometers operation, and if the tachometer operates as it should, then the regulator/rectifier is faulty and will require replacing. If the tachometer is still faulty, replace the tachometer.
If neither of the yellow wires from the stator is yellow/gray, and neither is attached to a yellow/gray wire, then attach that gray tachometer wire to either yellow stator wire, then the other yellow wire, checking the tachometer operation on both connections.
I've found this method to be a quick and efficient way of finding out which component is faulty.... the tachometer or the regulator/rectifier. It sounds drawn out but really only takes a very short time to run through. If the water cooled regulator/rectifier proves to be faulty, don't put off replacing it as they have been known to catch on fire with disastrous consequences.
I was assuming that indeed you had checked the spark and found it to be erratic/faulty. If not... check the compression and spark. Compression gauges are cheap and available just about everywhere. A spark tester can be found at any automotive parts store... the spark should jump a 7/16" gap with a strong blue lightning like flame... a real SNAP!
For a poor mans spark tester, you can also (with all plugs removed) use a #2 philips screwdriver tip inserted into the spring within the plug boot, then hold it a average 7/16" away from the block while cranking.
In reading your initial post over closely, you mention that the engine had set for some time. That could bring into view fouled carburetors... I assume the 1994 model has carburetors.
If so, remove the brass drain screw from the float chambers and examine the back portion of the screw for discoloration, debris, etc. They may have fouled and require cleaning/rebuilding. Should you decide to clean the carburetors, be sure to clean the high speed jet, which is located horizontally in the bottom center of the float chamber, with a piece of single strand steel wire as solvent just doesn't do that job properly.
The mention of barely screwing a spark plug in (a few threads only?) to start the engine is not a good idea. The explosion within the cylinder has been known to blow the threads away and having the spark plug go thru the cowling (deadly!).
luv2fish1987
Ok so maybe this will help rather it be good or bad after messing around with it today with a little help I put my spark tester on it and am only getting spark on one cylinder on the port side middle cylinder tried changing plugs and wires around and even swapped coils around and it still got spark on only that one cylinder not sure if this helps but maybe its a step in the right direction
Joe Reeves
If you had all the spark plugs out doing that spark test, fine. If not, remove "all" the plugs and redo the test.
Assuming you did have all the s/plugs removed... that would lead me straight to the large black coils I mentioned on the stator.
luv2fish1987
i did not have all the plugs pulled out but i will pull the plugs and try it again however i swapped the stator out with a used one a while back i was told the stator worked but it looked really rough however i did leave it on also when i went out to try to start the boat the motor was cranking slow and i found out the battery that was not even a year old went bad so i got a new battery and now i got spark on the one cylinder so i am going to put old stator back on and try again thanks again for all the help as confusing as i may be i feel we are getting somewhere
