94 Evenrude 15hp - Hard starting
mikeschumann
I have been have lots of problems starting this engine. Out of desperation, I opened up the case. When I moved the red lever in the attached photo to the up position, it created a hissing noise. I put the lever back down and the engine started fine.
1. What exactly does this lever do?
2. What are the potential underlying problems here?
Honorary Supreme Mariner
That unit is the electric primer valve.-----Pushing the key in while cranking the motor over ??-----The red lever opens the electric primer valve.----Used should you have a dead battery.
