nando02
Thread starter- Joined
- Jun 15, 2016
- 5
Hello all, I've been reading posts for a couple weeks now but just haven't been able figure out what the issue is I'm having. Could use a little help before taking it into the shop...
I am a new boat owner, just bought a 1994 Sunbird fish/ski combo with a 90hp V4 Johnson 2-stroke (same year). It ran perfectly fine when I bought it, including the first 4-5 times I took it out. Then, a couple weeks ago, it wouldn't start at the dock. I noticed a little fuel leaking out of the intake manifold cover and could see there were some cracks and the gasket was shot. So I replaced that and, while I had it off, sprayed a small bit of starting fluid into the manifold. After that, it started right up, ran and idled fine in the driveway with the hose hooked up. About a week later, I took it out on the lake and it started on the first turn - ran for about 15 minutes before dying while idling. Couldn't get it to start, had to get a tow back to the dock... I got it back into the driveway and hooked up the hose again. I checked the fuel lines and noticed one was kinked pretty bad - straightened that out and it actually started right away after a prime. But of course, I left the accessories switch turned on and the batteries died. I charged the batteries and tried starting it again - no dice and still haven't been able to get it started.
I've checked the fuel lines - no leaks. Loosened a screw on the manifold cover and some fuel leaked out - so there is fuel getting in there. Made sure the primer bulb was working by pumping it without the quick-connect attached to the outboard and pressing the pin with a screw driver.
My only thought at this point is maybe a spark plug is shot - but would it be able to start with starting fluid if a plug isn't firing? I have no idea where to go from here and am learning everything as I go. I know it's a long first post, but I didn't want to waste anyone's time by leaving out information and what I've done thus far. I have a video of it trying to start if that would help. Based on a little research, it sounds like it could also be a vapor lock situation (maybe), but I honestly have no idea at this point.
Thanks in advance for the help!
