jimmye4fish
Thread starter- Joined
- Mar 16, 2004
- 7
Ive got a 94 90hp Force by Merc. When I get to the lake it starts right up and purrs like a kitten. I can run it from an idle to wide open for about as long as I want. After I shut it off and fish for a few hours and crank it back up it starts right up. But everytime I go to give it some throttle it boggs down and dies. It will do this once or as many as 30 times. Then it runs great again. I pulled the carbs off last night and visually inspected them and inside the bowls. All looked clean. I checked the filter and it doesnt have any restrictions and is clean. I had just replaced the plugs before I backed it in the water. When I checked them they had a little oil on them, not bad. There is some sort of vacum valve that has a hose that runs from the top carb bowl to it and the other vacum line on it runs to the manifold. The one coming from the bowl is full of gas but I would imagine it should . This is all I can think of for now. Any suggestions ?
I plan on taking it back out Friday. Thanks !
