fattypackard
Thread starter- Joined
- Jan 23, 2010
- 33
update at bottom!
hey all, i FINALLY got this thing running well after a rebuild on the carbs and adjusting the throttle linkage.
so after that....i took the boat out to test it out.
it wont go past 10/20 mph. it has no power.
what are some things to look at that could cause this...?
i know the compression is good (120/118/118....when cold)
should i take the jet pump assembly apart to see if the impellor is worn out?
would the starter cause this issue? because i think the starter is going out. it slow cranks a lot. gets stuck. on when the motor is running, when i put it in gear etc....the starter gear spins and moves up and down.
any ideas? TIA
any ideas? TIA
