TeachersPet
- Aug 12, 2009
- 1
I have had this boat for about two years and about halfway through this season I noticed some trouble shifting into the Forward gear. It has no trouble shifting into reverse but when I try to put it into a foward shift the motor starts to click reapeatedly like it is trying to shift. Then after increasing the RPM's by pushing the throttle forward it will go into forward. I don't want to wreck the gears by increasing these RPM's to put it into gear. Should I replace the forward gear and pinion, clutch/shift cables or am I missing another option? Also sometimes when it is in the forward gear it starts to make a buzzing sound out of where you push the throttle forward and back. Is this a related problem or different?
