I recently purchased a 2003 boat with a 115 johnson but the engine was shot so I put a 94 140 evinrude on that hull which everything seemed to match perfect. The 140 had previously spent 24 hours under water due to submerged stumps but after we retrieved it , put it on a stand, pulled plugs and lubricated cylinders it started immediately. Die Hard. the coil pack was changed as a precautionary.
The motor starts immediately and idles fine but upon acceleration it boggs down drastically and starts popping and hesitating. Is there anything different from a 115 johnson and a 140 evinrude controls that i should look for? My compression and firing is good. Lost???
